Vantage Benchmark für alle Alienware gestartet
VSS
Alienware Benchmark Ergebnisse
3DMark Vantage Download Link:
http://www.futuremar.../3dmarkvantage/
3DMark Vantage Patch:
http://www.futuremar...mva_hotfix_101/
Benchmark nur im PERFORMANCE test, ohne Feature Tests und PHYSX !!!
Resultate nur mit CPU-Z , GPU-Z und Vantage score
hier muster
NVIDIA
[*] USER - x.xxx pkt. - NVIDIA GeForce MODEL VRAM @ GPU @ MEM @ SHAD - Procesor @ x.xGHz Screen
AMD
[*] USER - x.xxx pkt. - AMD MODEL VRAM @ GPU @ MEM - Procesor @ x.xGHz Screen
Multi GPU
[1] VSS - 22.122 pkt. - AMD 6990 CF 2048 VRAM @820 GPU @1050 MEM - I7 2630 @ 2.8GHz Screen
Single GPU
nVidia
GTX580
[1]
VSS
- 16.950 pkt.
nVidia GTX580M
2048 VRAM @750 GPU @875 MEM
I7 2760 @ 3.6GHz
2]Kabinenbrunser - 16.633 pkt. - Nvidia GTX 580M 2048 VRAM @750 GPU @1500 Shader @875 Mem - I7 2860 @ 3289MHz Screen
[3]JonnyDee - P15.812 pkt. NVIDIA GTX 580m 2048VRAM @750 GPU @800 MEM @1500 SHAD - I7 2630qm @ 2,0GHz Screen
[4] Kabinenbrunser - 15.658 pkt. - Nvidia GTX 580M 2048 VRAM @700 GPU @1400 Shader @850 Mem - I7 2720 @ 2990MHz Screen
GTX560
GTX555
[1]Darkened Sky - 6165 pkt. - Nvidia Geforce GT 555m 3GB @590MHz @900MHz @1180MHz - i72820 @ 3.1GHz Screen
GTX460
[1] Angus - 9.699 pkt. - NVIDIA GTX460 1536VRAM @800 GPU @1400 MEM @1600 SHAD - I7 2630qm @ 2,8 GHz Screen
[2] meenzerbub84 - 9.288 pkt. - NVIDIA GTX460 1536VRAM @774GPU @1250 MEM @1548 SHAD - I7 2720qm @ 3.2 GHz Screen
[3] Angus - 8.390 pkt. - NVIDIA GTX460 1536VRAM @675 GPU @1250 MEM @1350 SHAD - I7 2630qm @ 2,6 GHz Screen
AMD
HD 6990
[1] VSS - 17.030 pkt. - AMD 6990 2048 VRAM @865 GPU @1140 MEM - I7 2760 @ 3.6GHz screen
HD 6970
[1] svl7 - 15.745 pkt. - AMD 6970 VRAM @ 860GPU @1100 MEM - I7 920xm 3.45GHz Screen
HD 5870
Intel IGPU
Nur im Entry mode
M11x
M14x
M17x
M18x
[1] VSS - 12.188 pkt. - Intel HD 3000 1300@1644 - I7 2670@3.6 GHz
screen
3DMark 11 Download Link:
Download 3DMark 11 | 3DMark 11 – The Gamer's Benchmark for DirectX 11
3DMark 11 patch :
Resultate nur mit CPU-Z , GPU-Z und 3d11 score
hier muster
NVIDIA
AMD
Multi GPU
MULTI GPU
[1] VSS - 7.902 pkt. - AMD HD6990CFX 2048VRAM @ 805 @ 1100 - I7 2760@ 3.56GHz Screen
Nvidia GPUs
GTX580
GTX 560
GTX555
GTX485
GTX470
GTX460
AMD GPUs
HD6990
[1]VSS - 4.065 pkt. - AMD HD6990 2048VRAM @ 830 @ 1150 - I7 2760@ 3.6GHz Screen
HD6970
HD6870
HD5870
HD5850
Bearbeitet von VSS
  • Antworten 62
  • Erstellt
  • Letzte Antwort
Top-Benutzer in diesem Thema
Veröffentlichte Bilder
im Prinzip Hardware ist fast gleiche und hier wird nur cpu und gpu bewertet , kann auch sein das M15x schnell genug ist um M17x zu überholen :34:
Ergebnisse nur nach Muster bitte eingeben dann kann ich auch rein ins erste Post einfügen ,
hab ja 1600er Speicher eingebaut und kleine vantage Test :
Solange der Vergleich oben nicht erweitert wird ist der threat sinnlos, weils ähnliche schon gibt. Eine nette Vergleichsliste ist zwar net aber ohne Vergleichswerte sinnlos ;-)
kannst auf deine pix im paint gewünschte Graffiti malen ob du mehr Pscore damit erreichst ist jedoch fraglich ,
@cyrik
bitte lass mal deine Ergebnis hier mal Posten
trag erstmal die geposteten Scores oben in deine Liste ein, weil Übersicht hat man hier nicht ^^
Und mein Notebook wird grad noch produziert da kann ich es schlecht testen *g*
mache ich aber gerne nur unser muss wie im Muster seine Ergebnisse Posten
hier muster
NVIDIA
AMD
hab ja heute mal die interne gpu mal an Stress grenze gebracht
hier Vergleich zu HD4550
edit ,
habs ausprobiert Cap profile und mit CAP3 habe ich bessere Performance erreicht :
Bearbeitet von VSS
Ich habe meine Scores schon lange gepostet... macht es dir wirklich zu viel Mühe es selbst zu formatieren? Du musst den Link so oder so selbst reinkopieren...
ist so schwer ?,
ich kopiere das ganze und füge ein ins erste post
---------- Beitrag hinzugefügt um 18:44 ---------- Ursprünglicher Beitrag wurde erstellt um 18:27 ----------
meine beiden Vantage Scores: Standard GTX460m gegen GTX460m@GTX560m
[ATTACH=CONFIG]1288[/ATTACH]
[1] meenzerbub84 - 9.288 pkt. - NVIDIA GTX460 1536VRAM @ 774GPU @1250 MEM @1548 SHAD - I7 2720qm @ 3.2 GHz Screen
Ich habe mal mit dem neuen Battlefield 3 Beta-Treiber getestet und für den normalen sowie overclock Betrieb sind folgende Werte bei rausgekommen:
[1] Angus - 9.699 pkt. - NVIDIA GTX460 1536VRAM @800 GPU @1400 MEM @1600 SHAD - I7 2630qm @ 2,8 GHz post-1-14366120868298_thumb.jpg
[3] Angus - 8.390 pkt. - NVIDIA GTX460 1536VRAM @675 GPU @1250 MEM @1350 SHAD - I7 2630qm @ 2,6 GHz post-1-14366120867244_thumb.jpg
Standart:
Kabinenbrunser - 14.417 pkt. - Nvidia GTX 580M 2048 VRAM @620 GPU @1240 Shader @1500 Mem - I7 2720 @ 2990MHz
OC:
Kabinenbrunser - 15.658 pkt. - Nvidia GTX 580M 2048 VRAM @700 GPU @1400 Shader @1700 Mem - I7 2720 @ 2990MHz
ohne trotteling wäre noch mehr drin gewesen...
kleines Update mit neuem VBios:D:
Kabinenbrunser - 16.036 pkt. - Nvidia GTX 580M 2048 VRAM @714 GPU @1428 Shader @1725 Mem - I7 2720 @ 3189MHz
Bearbeitet von Kabinenbrunser
  • 4 Wochen später...
3d Mark Vantage
JonnyDee - P15.812 pkt.:D ohne PhysX- NVIDIA GTX 580m 2048VRAM @750 GPU @1600 MEM @1500 SHAD - I7 2630qm
JonnyDee - P18.127pkt.:D mit PhysX- NVIDIA GTX 580m 2048VRAM @750 GPU @1600 MEM @1500 SHAD- I7 2630qm--
3d Mark 11
JonnyDee - P3.556pkt.:D mit PhysX- NVIDIA GTX 580m 2048VRAM @750 GPU @1600 MEM @1500 SHAD- I7 2630qm
MfG
da
Jonny
Bearbeitet von JonnyDee
macht mal den vantage damit man besser vergleichen kann... der erste post im thread sacht auch 3d vantage deswegen passen die anderen er weniger... man könne auch noch 2 weitere eröffnen in dem dann der 06 und der 11er 3dmark gepostet werden kann
oder VSS legt noch ne übersicht mit an für 3d 06 und 11
so würde man das besser sehen de nen freund schon gefragt hat wie der 2. platzierte sich dich am erstplatzierten drann sein kann, nach sicht auf dem sceen weis man es.... 1. 3dvantage 2. 3d06
MfG
da
Jonny
ein 3d06 und 3d11 mit dem vantage wird schwierig zu editieren und mit dem zeit wird das ganze zu lang , ein separate 3d11 kann ich noch eröffnen nur wenn nachfrage kommt ,
wollte anmerken das der bech von kabienenbrunser glaube ein 3d Mark 06 ist und kein Vantage
das Bild stammt aus vantage Benchmark.
